I had to re-install Windows due to a malware problem and my registration key no longer works after I re-installed the product. I bought a lifetime upgrade version. Advice needed please.
Thank you,
Carol Steele
Registratio Key no longer works
Re: Registratio Key no longer works
You're using the one starting with AHY6 ?
Looks like it should be working from our side of things, are you getting a specific error ?
- Carol_S
I tried registering again this morning - and this time it worked. Can't see what I did differently as I was copying from a text file with all the parameters for setting up my email accounts I had created from my previous setup before I did the fresh install of Windows.
Sorry to have troubled you.
