imap not connecting
andromeda_girl
imap not connecting
Tue May 03, 2022 7:54 pm
MWpro [v7.12.67] is not connecting to imap servers at all, it did previously w/o issues.
i have made no changes to my MWpro application [that is to say, any of the settings for connecting to my emails]
either to my emails nor in MWpro yet suddenly MWpro can no longer connect to imap.
what might be ther trouble here please?
AdmiralSirJohn
Re: imap not connecting
Thu May 05, 2022 12:56 pm
Sorry to hijack the thread, but I'm having the same problem, both with imap and pop3. Neither Gmail nor Spectrum (with the mail.twc.com server) will connect. The log gives the following "unknown error" along with the "cannot connect" error:
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>b147c5491618223bff6a5383355f874a</ID><DT>2022-05-04 20:54:35</DT><MWPEXCEPTION><UID>Exception 75beb9572fd94967aa18743ecd5b73a8</UID><AID>Failed after retries</AID><SOURCE>MWP_IMAP::IMAPconnect</SOURCE><MESSAGE>Gmail</MESSAGE><EXCEPTION><SOURCE>MWP_IMAP::IMAPconnect</SOURCE><ADD_ID>Failed after retries</ADD_ID><MSG>Gmail</MSG></EXCEPTION></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>93f460b48cf250f097995b027414f2f7</ID><DT>2022-05-04 20:54:35</DT><MWPEXCEPTION><UID>Exception d715e256c55b40f1b58aaeee6fcf7971</UID><AID>Failed after retries</AID><SOURCE>MWP_IMAP::IMAPconnect</SOURCE><MESSAGE>Footballbat</MESSAGE><EXCEPTION><SOURCE>MWP_IMAP::IMAPconnect</SOURCE><ADD_ID>Failed after retries</ADD_ID><MSG>Footballbat</MSG></EXCEPTION></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
If anyone can help, I'm sure we'd both appreciate it.
Thu May 05, 2022 1:49 pm
Has it come right ? If everything was working I would expect a temporary issue. Was this all accounts, and are they all GMail ?
Those are timeouts, MailWasher is trying to connect and failing to establish a connection. Given two different servers are failing to connect, this would probably suggest a software firewall program you have running that might be blocking the connection. Do you have any security software installed that might be doing this ?
AdmiralSirJohn
Fri May 06, 2022 8:22 am
Nope. No changes in security software AT ALL. Early Tuesday, it was working, late Tuesday and since, it wasn't.
AdmiralSirJohn
Fri May 06, 2022 9:04 am
And it's working again.
Here's what I did:
First, I disabled by email scanner in AVG.
Then...
For Gmail - Changed incoming encryption to TLS and changed the incoming port to 587. I then went to my Google account and under security, I generated a password using the instructions posted in the pinned post above.
For Spectrum - I just re-added the accounts per the instructions on Spectrum's support page, using settings for my local rr.com domain.
And then it started working.
It's likely some update in AVG to make the email scanner to make it too aggressive.
