Microsoft 365 Exchange
metricman
Wed Jun 29, 2022 2:45 am
I use GoDaddy for a website that I maintain. They have switched to Microsoft 365 Exchange and apparently there is no way to use MailWasher to access my email.
Any way I can access my email at GoDaddy using MailWasher?
Re: Microsoft 365 Exchange
Thu Jun 30, 2022 2:51 am
You should still be able to use IMAP to access the account, I can't imagine they would disable that.
https://nz.godaddy.com/help/use-imap-se ... lient-4714
Try those settings mentioned on that page.
metricman
Tue Jul 12, 2022 10:41 am
That is what MailWasher was set to and it quit working. Outlook had to be modified by software to retrieve my email. You had to click on a button at GoDaddy and a program modified Outlook for you. It even had my email address correct.
Copy of email:
URGENT ACTION REQUIRED
Update your settings now to keep your email access working.
A service your email relies on to function will no longer be supported by Microsoft after 06/28/2022. You'll still be able to access your email through your browser, but not from an email client, such as Outlook or Apple Mail — don't worry, none of your emails will be lost.
To avoid this disruption, you'll need to update your email settings. This is necessary for each device you check your email on.
Update Your Settings
If you have other users on your accounts, they'll need to update their settings, too.
Here are the addresses that will be affected:
Please do not reply to this email. Emails sent to this address will not be answered.
Copyright © 1999-2022 GoDaddy Operating Company, LLC. 2155 E. GoDaddy Way, Tempe, AZ 85284 USA. All rights rese
KaraciaJM
Tue Jul 12, 2022 3:21 pm
Yep, I got the same email from GoDaddy. They killed POP/IMAP and only do Exchange now. So, my mailwasher doesn't work for 2/3 of my accounts now. :(
What is the chances you guy can get this corrected?
Also, super happy that they did this right before the 4th of July Holiday.
Sat Feb 11, 2023 7:02 am
Yea, that sucks alright, however yes, we do plan do add Exchange support to MWP, but could be quite some time away.... sorry!
hewiep
Sat May 27, 2023 1:41 am
I am a long-time lifetime user of Mailwasher. My main email accounts are located at GoDaddy, which is Exchange. I cannot use Mailwaher without those accounts. Please add that capability (use Exchange accounts) as soon as possible. Thank you.
Hewie Poplock
Sat May 27, 2023 6:58 am
Yes, we're getting a lot of reports godaddy accounts are not working since their changes, but from what we understand, they 'should' work via IMAP/OAUTH still, so we're still looking into this and are in contact with godaddy about it, I'll post here once we either get it working find out it wont indeed work via IMAP any longer...
And yes, Exchange support is on the to-do list also, but no date on this still sorry...
kiwioz1
Thu Jun 15, 2023 10:02 pm
I have just joined the queue.
I have a GoDaddy account and now have to use Exchange since my renewal with GoDaddy
I have use "The Bat" as my mail client for 22 years. There is no word from them of updating for Exchange so far.
One thin I am seeing is so much in the Outlook Junk folder
Fri Jun 16, 2023 6:57 am
Yes, still working on the godaddy issue, hoping for a new beta we can try soon!
Wed Jul 05, 2023 12:36 pm
Hi there, we have a beta you can try, however due to gmail issues with this, not keen to posts it here, please email support at firetrust dot com and I can send it to anyone who would like to try it...
Note that gmail issues are if you make any changes to a gmail account, you cannot currently change them in MWpro, current Gmail accounts already setup will continue to work OK however.
kiwioz1
Fri Jul 07, 2023 2:57 pm
I can now use Mailwasher with My GoDaddy MS365 Exhange account!
It's been a bit of a battl e but these are settings I got from a GoDaddy online chat yesterday I have edited:-
Here are the server setting which are for IMAP.
Incoming settingsServer name: outlook.office365.com (POP/IMAP)Port: POP: 995 with SSL selected IMAP: 993 with SSL selectedEncryption
method: TLS (POP/IMAP)
Outgoing settingsServer name: smtp.office365.comPort: 587Encryption method: STARTTLS
Next task is to get it to work with my Mail Client
Fri Jul 07, 2023 3:25 pm
Great, glad to hear it's working for you now, and yes, so far most users report no problems with godaddy accounts and the new beta......
