Win 11 Pro 64 Bit
oz9fb
Win 11 Pro 64 Bit
Thu Sep 08, 2022 4:28 am
My old win 10 Pc will be retired and changed to a new Lenovo Pc with Win 11 Pro.
Right now I'm using MW 7.12.67 can I use this version on my new Win 11 Pc. ?
I Also use Hideaway version v4.19.1 can this be used also on my new Win 11. ?
Regards
Frank
Re: Win 11 Pro 64 Bit
Thu Sep 08, 2022 9:46 am
Yup, both will work fine on the new machine.
If you want to create a MailWasher backup file on the old, to run on the new machine and have all your data present, then go File >> Export >> give the file a name and save location, set to include Learning also >> Export.
That creates a *.mwp file, then on the new machine install MailWasher first, then run the .mwp file to import all the accounts, settings etc...
Or, if you're like me and like a quick fix to most programs you use, then you can ZIP and make a copy of your entire C:\Users\[your username]\AppData\Roaming\ folder.
Typically most programs you use keep their data files there, so when you install the programs on the new machine your previous configurations are already there.
oz9fb
Thu Sep 08, 2022 1:18 pm
Thanks rusticdog.
Regards
Frank
