My Windows 10 is on it's knees and I can't take it anymore so I'm preparing for a drive format and clean install of Windows 11. That is to say, not an upgrade.
My question is will MWP7 recognise the hardware ID's within my system and take my licence key without grief, or will it spit me out?
I like to be prepared before I trash a system so am checking in advance.
Thank you.
MWP7 Licence after Disk Format
Re: MWP7 Licence after Disk Format
Yes, should work fine, but if any problems, email support and they can reset your key... .note also FYI....
Here's how to transfer to your new PC..
First, install MWPro 7 to your new PC from here:
http://www.firetrust.com/en/products/ma ... o/download
Then, to transfer your old data, (OPTIONAL) on the old PC's MWPro installation click File>>Export, and save the exported file somewhere you can locate it to move it to your new PC.
Note you can also click Help>>Registration on the old MWPro installation and get your registration key from there if required.
Then, within MWPro on the new PC click File>>Import and import this file.
- crazy4mail
Noted.
Thanks again gingbat.
If only all the other software would transfer that easy...
