Unknown Error
daven
Unknown Error
Fri Mar 10, 2023 1:11 pm
This is coming up way too frequently and only seems to have started after the most recent upgrade. I am on 7.12.125
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>ae5f6fc3cf69c7cee03617f2ee1a5978</ID><DT>2023-03-09 16:06:33</DT><MWPEXCEPTION><UID>Exception e0ea027e8d0021e9df7e98860cb4170b</UID><AID>Acct-1223385162</AID><SOURCE>IMAPservice::PipelineEmailLinesToCache</SOURCE><MESSAGE>SocketException - GetLine failed() failed with code 0: The operation completed successfully.</MESSAGE><ADDXML></ADDXML></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
Re: Unknown Error
Fri Mar 10, 2023 2:17 pm
Usually socket errors mean that your firewall, antivirus programs email scanner or other security software has blocked MWPro from checking mail there? Please check the settings in there to ensure MW is allowed full internet access, and has no rules either blocking it, or incorrectly setup which could cause issues. If no, or no better, is there an Antivirus email scanner active on your PC there? (Within your antivirus or firewall software), maybe try disabling this and see if that helps?
(NOTE: the antivirus real time scanner will still scan any emails and attachments for viruses anyway, so you are quite safe)
If still problems, probably the best option here is to try deleting the problem email account and re-importing it....
(First though, click File>>Export and save a copy of your settings to file for a backup)
Settings available here (for most ISP's but not personal domains) if you need them: http://www.emailsettings.email/
