Crashing as it checks for spam
rkrazor
Sat Sep 02, 2023 12:23 pm
Tonight when i opened the program on both my desktop and laptop it starts to check mail. Loads all the mail, then as it's checking against the spam the program crashes. I don't have time to click on send support logs before it goes away. I have deleted the startup.xml, spamreporting.xml, display.xml, and the accounts.xml
The program rebuilds them, including finding all my emails, then it crashes.
please advise. Thanks in advance.
Anysia
Re: Crashing as it checks for spam
Sat Sep 02, 2023 12:32 pm
Having the same problem. I have also done all the above deletion of xml files, and still it crashes. And it just started this morning.
Help?
petercr
Sat Sep 02, 2023 12:47 pm
Add me to the list too. I thought it might have been a Win11 update as I'm on one of the Insider programs but I'm getting exactly the same as others. Totally deleting the app, rebooting and installing fresh doesn't see to fix it.
Sat Sep 02, 2023 12:57 pm
Sorry about that, seems there was a hardware issue, just fixed apparently, so should be all go now....?
petercr
Sat Sep 02, 2023 1:01 pm
Nope - just opened MW. it checked for emails then started to classify emails and crashed (not even to a background task)
rkrazor
Sat Sep 02, 2023 1:13 pm
Nope still crashing :(
Sat Sep 02, 2023 1:25 pm
:facepalm .....please hold the line.....
Tenton12
Sat Sep 02, 2023 1:53 pm
Same thing just started happening to me today, crashing out as it evaluates a message. Thought it may have been a spam message so logged into my provider's webmail and no, it was just a normal message from a sender I've received many messages from before.
Cooz
Sat Sep 02, 2023 2:12 pm
Happening here too.
Any solutions yet?
It just started this evening US East Coast at 10:00 pm.
Sat Sep 02, 2023 2:13 pm
OK, can you please try disabling Firstalert, as we've noticed a few users having issues with this:
(when MW starts, click Stop, to stop the mail check first)
Settings>>Spam Tools>>Firstalert, uncheck, "Use Firstalert" and click Save.
If no better, disable any servers listed under Settings>>Spam Tools>>Origin of Spam, click Save.
Let me know if either helps?
winday
Sat Sep 02, 2023 2:14 pm
Happening to me too -- was working fine earlier today.
Sorry, posted my reply before I saw the note about disabling FirstAlert. That helped.
Cooz
Sat Sep 02, 2023 2:17 pm
Disabling FirstAlert seems to be working.
It's a trick to get to the "Stop" before the program crashes but I was able to get it.
Anysia
Sat Sep 02, 2023 2:18 pm
I ended up rolling back to previous version until they get this glitch fixed.
Sat Sep 02, 2023 2:22 pm
NOTE: if you cannot do the above because MW crashes before you can stop the mail check, try this.....
Go to Start, type run (then click the Run file so it runs) then in the ‘Open:’ box type (or copy / paste):
%AppData%\Firetrust\MailWasher
Rename the current "SpamToolSettings.xml" file to "SpamToolSettingsOLD.xml" (or remove it).
Then move the attached one into the same folder.
Start MWpro.
(902 Bytes) Downloaded 433 times
Anysia
Sat Sep 02, 2023 2:54 pm
I disabled it in the rolled back version, updated to latest, and disabling Firstalert. All good.
