An unknown error has occurred. MailWasher is unable to determine the cause of this error.
DirectoryDude
Sun Nov 12, 2023 2:24 pm
All Email addresses including Yahoo, Gmail, and Verizon
Description: Check Mail has been requested for your "[email protected] account".
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>da1727bca21e39811480f4bf683277dc</ID><DT>2023-11-11 20:06:54</DT><MWPEXCEPTION><UID>Exception a5d1cf3d25311a26c64d7c098c4385a3</UID><AID>Acct1201819931</AID><SOURCE>MWPfetch::FetchThread()</SOURCE><MESSAGE>StdException - Unknown exception</MESSAGE><ADDXML></ADDXML></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
I have no Idea How to get the log file to be inserted here.
I checked the firewall on the server and my IP is whitelisted. I checked mod security no entry. I restarted the mail server even though it's happening to the 3, not on my server.
I shut off Malwarebytes and still no good
EDITED: I just checked deleted mail on there is none in the recycled bin. I went back 30 days empty, nada, gone. I rebooted and checked the same. I restated the mailwasher nothing and checked all times nothing.
Mitch
3alienswebhosting dot com Out of this World Web Hosting
sjmiller
Re: An unknown error has occurred. MailWasher is unable to determine the cause of this error.
Sun Nov 12, 2023 2:37 pm
I just started to get this same error. It happened suddenly. I was attempting to Wash Mail when Mailwasher suddenly crashed. I haven't been able to get it working since. Uninstalled multiple times, rebooted, etc. My email accounts are still working correctly from other mail clients. If multiple people are suddenly seeing the same error, it seems like it might be a date or timestamp bug.
garydingle
Sun Nov 12, 2023 3:56 pm
I too, got this error when first running the app today. V7.12.173
Ran repair, but no good.
Uninstalled & reinstalled, but no good.
Uninstalled & went back to V7.12.125 and that fixed the problem.
Gary
Anysia
Sun Nov 12, 2023 4:15 pm
Same here. I have tried Repair/Uninstall-Reinstall/Manually adding emails address. Tried sending the log directly to Firetrust via Mailwasher and even that errored out. This was for my IP email address.
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>b4b64b0fab4ef624355f47e48b6e2ff7</ID><DT>2023-11-12 11:11:25</DT><MWPEXCEPTION><UID>Exception 0ada61decc4a8ac0f88f9315cbeafacc</UID><AID>MWPlogsDll::DoCommand</AID><SOURCE>MWPlogsDll::DoCommand</SOURCE><MESSAGE>StdException - Logging send log lines failed</MESSAGE><EXCEPTION><SOURCE>MWPlogsDll::DoCommand</SOURCE><ADD_ID>MWPlogsDll::DoCommand</ADD_ID><MSG>StdException - Logging send log lines failed</MSG></EXCEPTION></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
EDIT: I reinstalled earlier version. 7.12.125, and the problem disappeared.
Pancake
Sun Nov 12, 2023 4:22 pm
I have that same problem, no emails coming in just unknown problem. I am using latest version. I might try an old one.
rkol801
Sun Nov 12, 2023 4:24 pm
Add one more, same symptoms. Second try at posting, first one may be stuck in moderation.
DirectoryDude
Sun Nov 12, 2023 4:26 pm
Maybe their Server that checks registration is down?
Mitch
rkrazor
Sun Nov 12, 2023 4:36 pm
Add another one having the same error, tested on two different machines.
LazyDave1970
Sun Nov 12, 2023 4:38 pm
Having the same issue, uninstalled, reinstalled as above, decided to knock my clock back 1 day and it worked flawlessly, rebooted back to normal errors again, something it doesn't like as soon as the clock and date hit a couple hours ago. might be a cert issue on Firetrust's side.
Pancake
Sun Nov 12, 2023 4:41 pm
Reinstalled earlier version. 7.12.125, and the problem is gone.
Sun Nov 12, 2023 5:17 pm
Yes, sorry about this, not sure what's going on as yet, but the above may well be right.... mine is failing too, seems to have started around 1PM today (Sunday) NZ time... oddly enough, the older 7.12.167 version I have on a windows 8 VM is working fine still though... checking up on this and will report back as soon as I find out what's happening..... just gotta get hold of someone to look at it as it's Sunday evening here in NZ.....
Assured
Sun Nov 12, 2023 5:18 pm
I just set my clock back also, and that worked! I was having the same problem on my client, Eudora, and with the date set back, it worked also. But, I had 2 folders for Eudora, and one of them never stopped working. Maybe that will help figure out the real problem.
After checking mail, I set the time to the current date and time and mailwasher stopped working again.
Super-T
Sun Nov 12, 2023 5:37 pm
Same problem here and can't reload the earlier download as it says "Mailwasher already has a later version installed" Setting clock back fixes. I think there was an update earlier today.
Sun Nov 12, 2023 5:56 pm
This is pretty weird, there shouldn't be any dependency on any outside service which stops people checking their email. Looking in to it.
Super-T
Sun Nov 12, 2023 6:05 pm
Bottom left corner shows a circling asterisk so I guess it isn't contacting somewhere
