Wrong Update Offered
Arnak
Sat Nov 18, 2023 7:47 am
I have MW Pro 7.12.188 and when I check for updates I am offered the free version 7.12.6 :(
I am using W10.
Any ideas why this is happening, please?
Martin
Re: Wrong Update Offered
Sat Nov 18, 2023 8:11 am
Yes, sorry about that, this can happen sometimes if update from the Free version to the Pro version.
Please backup first via File>>Export, (you likely wont need this, just in case any problems), then uninstall MWPro and click YES to save your user data files.
Restart your PC and reinstall from here:
Arnak
Sat Nov 18, 2023 8:41 am
Hi, thanks for the reply.
Happily, it didn't catch me as I noticed it was the free version and didn't install it.
Martin
