Checking non-default accounts 'sticks'
- iamjaydear
The default accounts are all checked every time MWP does the periodic checks. That's as expected and makes complete sense. If you check a non-default account by pulling down the In Tray menu and clicking one non-default account it is checked as expected. However, that account then joins the queue in the periodic check which is somewhat of a nuisance. Is this a bug or is there some way of checking a non-default account so that it won't be checked periodically, i.e. just once? Restarting MWP clears the stuck account check, but that shouldn't be necessary
I'm using v7.12.188.
Re: Checking non-default accounts 'sticks'
Yes, that is normal operation, if you don't want the non default accounts checked with every mail check from then on, just click C to clear the message list. then only the default accounts will be checked again...
- iamjaydear
Thanks for that hint. Took me a while to figure out where C was hiding
It works sometimes... C is ignored e.g. if you've used F5 to check mail, or if you've had the File, View or Help menus displayed and possibly other conditions. I haven't dug deep
yes, sorry about that, usually I write "C on the keyboard" ! and yes, the message list needs to be in focus at the time you click C or it wont work alright.... cheers!
