Text Size Adjustment
cfheinz
Guardian Gecko
Tue Jul 13, 2010 6:30 am
Thanks for adding this feature!! The small font size in the earlier version was an ongoing problem for me.
Carl Heinz
anniebrion
Re: Text Size Adjustment
Tue Jul 13, 2010 6:31 am
I had to change the DPI in windows as some of the settings windows are not alters by the text size in quick dispaly :(
Try adding a filter, on my PC the filter rules were a bit too small for my liking but you cannot change the test size in MWP :(
cfheinz
Guardian Gecko
Tue Jul 13, 2010 7:54 am
Clicking on the "Quick Display" and zooming on the text percentage let me do what I needed.
Carl Heinz
Tue Jul 13, 2010 1:44 pm
anniebrion wrote:I had to change the DPI in windows as some of the settings windows are not alters by the text size in quick dispaly :(
That might have been an oversight on our part, will see if we can fix that up.
Tue Jul 13, 2010 1:49 pm
I noticed the quick-display option goes hidden when you have a filter edit open, heavy regex users might really appreciate the zoom being available when deep into the codes. If it isn't easy to get too the zoom it would still be good to zoom all text, never really noticed it didn't zoom before but I've always had large fonts enabled.
anniebrion
Tue Jul 13, 2010 8:38 pm
Nice one :) Helps with my fading eyesight :D
cfheinz
Guardian Gecko
Sat Aug 28, 2010 6:22 am
Thanks for the boost in text size in the new release. :thumbsup
Carl Heinz
anniebrion
Sat Aug 28, 2010 6:26 am
cfheinz wrote:Thanks for the boost in text size in the new release. :thumbsup
Glad you like, It was my idea to increase to 200% :devil
