WailWasher Reverts to Trial/Wash Button Problem
cfheinz
Guardian Gecko
Wed Jul 14, 2010 4:30 am
When I booted up this morning, I noted that the "Wash" button was greyed out even though there were a number of messages. I clicked the icon for my email client and noted than none of the tagged messages had been deleted.
After processing the messages, I went to "Help" and displayed the "About" window and noted that I was back in trial mode. I reloaded my key successfully. Unfortunately, the "Wash" button continues to be greyed out on subsequent messages.
Carl Heinz
cfheinz
Guardian Gecko
Re: WailWasher Reverts to Trial/Wash Button Problem
Wed Jul 14, 2010 4:40 am
I closed and restarted MailWasher and now have the "Waswh" button back. Now to get rid of the new user display without having to first click on a message. I can't find the don't use new user display setting or a don't show this again button.
Carl Heinz
Wed Jul 14, 2010 4:48 am
cfheinz wrote: I can't find the don't use new user display setting or a don't show this again button.
Coming in next release, should be this week.
anniebrion
Wed Jul 14, 2010 4:50 am
cfheinz wrote:I closed and restarted MailWasher and now have the "Waswh" button back. Now to get rid of the new user display without having to first click on a message. I can't find the don't use new user display setting or a don't show this again button.
The ability to turn of the help text and cat from the preview pane is being tested ATM, there should be a pubic update soon.
It will be in the view menu "Preview Pane Graphic"
cfheinz
Guardian Gecko
Thu Jul 15, 2010 1:57 am
MailWasher was once again in "Trial" mode when I booted this morning. Had to re-register. Then I had to again close and restart MailWasher in order to have and active "Wash" button.
I how this isn't going to be a daily exercise.
Will have to check to see if I have log information.
Problem seems to only occur when restarting the computer after having shut it down over night.
Carl Heinz
Thu Jul 15, 2010 2:16 am
cfheinz wrote:Problem seems to only occur when restarting the computer after having shut it down over night.
There have been previous reports of some system creating a problem during shutdown. As a temporary work around try closing MWP manually before you shut down.
Also do you have MWP set to load on Start-Up of your system? If so that may be part of an issue related to the registration if the application loads before you have web connectivity. Try changing this setting, close MWP and then restart to see if the registration is correct.
cfheinz
Guardian Gecko
Thu Jul 15, 2010 2:33 am
This describes what occurs. I lack the expertise to cause WiFi start before starting MailWasher, though. Suggestions?
Carl Heinz
Thu Jul 15, 2010 2:34 am
cfheinz wrote:MailWasher was once again in "Trial" mode when I booted this morning. Had to re-register. Then I had to again close and restart MailWasher in order to have and active "Wash" button.
What happens if you don't re-register, but still restart MailWasher, does Wash become active ?
cfheinz
Guardian Gecko
Thu Jul 15, 2010 2:39 am
I haven't tried that, but I have restarted MailWasher during the day with no problem.
I think you've identified the lack of connectivity as the problem.
Why should that be a problem, though? Is MailWasher 2010 confirming the license each time it starts? Would seem that a cookie or registry entry would be a better solution.
Carl Heinz
MrBill
Prudent Pukeko
Thu Jul 15, 2010 2:40 am
I don't think being in Trial mode should cause the Wash button to be disabled - these are probably separate problems. They may have a common cause, though. I don't know how you have MWP set up - but if you are launching MWP automatically on startup, and automatically doing an immediate Check Mail, then it may be that Windows is still using excessive resources or hasn't connected to the Internet yet when MWP starts. Despite the theoretical multi-tasking capability of Windows, I always prefer to do things more or less one at a time - at least until Windows stabilizes after boot. I usually wait until Windows is up, and CPU and disk activity have dropped off, before I launch any programs. Once MWP is up, I usually wait 10-15 seconds before manually clicking Check Mail - just my own personal habit.
A greyed-out Wash Mail button usually means that evaluation of downloaded mail is still in progress. Sometimes this is because it has stalled, or the MailWasherProApp.exe has died. If the evaluation is stalled, try Stopping it, Clearing the grid, and doing a new Check Mail. If that works, MailWasherProApp.exe was ok. If it doesn't, the only recovery, as you have discovered, is to stop and restart MWP.
I'm not saying this is how things should work - just that it may help to diagnose the problem so it can be fixed.
Nice beard, BTW...
Bill Walton
Thu Jul 15, 2010 2:43 am
Yeah my suspicion is that we are seeing two problems here, because even if MailWasher was in Trial Mode, you should have a couple of weeks left and Wash Mail wouldn't disable. We also keep a cached copy of the Registration Certificate on your machine.
Seemingly you can reproduce this problem at will, so if you can make the problem happen where Wash is disabled >> then without making MailWasher work/restart etc...click Help >> Send Support Logs >> enter beta as the Ticket Number >> Send Logs.
cfheinz
Guardian Gecko
Thu Jul 15, 2010 2:51 am
Will do when I restart--probably tomorrow. I'll also let you know if there's no problem after my next cold start.
I don't really understand why the WiFi connect on this machine takes so long. It wasn't initially a problem. I suspect there's something in the Registry, but I'm an old green screen programmer and haven't developed the skills to tinker with it.
Carl Heinz
Thu Jul 15, 2010 3:05 am
I'm no expert on that either, I tend to just reformat when the machine starts slowing down.
Firewall would be my first guess, if that's slow to life then it certainly would prevent any internet access.
Thu Jul 15, 2010 3:09 am
cfheinz wrote:Will do when I restart--probably tomorrow. I'll also let you know if there's no problem after my next cold start.
Two things to try:
Change you settings so that MWP does not try to do fetch at load time or you disable MWP from loading at Windows start and then manually load it after you get connectivity.
cfheinz
Guardian Gecko
Thu Jul 15, 2010 3:17 am
Sidewinder wrote:Two things to try:
I don't understand the first option, but had planned to do the second if the problem persisted.
I don't recall the former as something in the Settings, but will take another look.
Carl Heinz
