email menu bug on todays build
philsbbs
Wed Jun 26, 2024 3:44 am
Does anyone else have this display issue with todays build on a windows 11 computer.
File attached.
Phil
missing description.jpg (34.21 KiB) Viewed 6106 times
Re: email menu bug on todays build
Wed Jun 26, 2024 9:15 am
Hi Phil, No, I can't say I've noticed that before... if you restart MW, does it re-appear?
If not, and the missing text never shows up, try reinstalling and click repair when asked....?
philsbbs
Thu Jun 27, 2024 4:20 am
it comes and goes also like this too..........
philsbbs
Thu Jun 27, 2024 4:25 am
missing opitions at the top.
philsbbs
Thu Jun 27, 2024 4:31 am
is it because its also missing the domain ?
did not have these issues before this weeks update.
philsbbs
Thu Jun 27, 2024 4:43 am
This person / domain is on the friends list but the status shows Good not Friend ?
philsbbs
Thu Jun 27, 2024 5:45 am
Done some more checks and every one that has no domain which it should gives the error where the top of the menu is cut off as per screenshot.
Thu Jun 27, 2024 6:08 am
Yes, unfortunately the blacklist issue we thought was resolved in the latest beta is not, had a few reports of this so far.. so back to the developer, hope to have it resolved for the next beta... sorry about that!
gerdzim
Sun Jul 14, 2024 9:46 am
Any news to this issue. I have the same problem. Mails are on friendslist also for Domains, but display only as OK
Does the developer have a solution?
Gerd
Sun Jul 14, 2024 4:57 pm
Yes, should be resolved, just waiting to be sent the beta to that that out though.. hopefully next week unless something new crops up!
philsbbs
Fri Aug 23, 2024 8:03 pm
Any news on the update the spam/status issue is a pain in the butt.
Sat Aug 24, 2024 7:43 am
sorry, still working on this, thought was resolved but no... :(
Sun Dec 01, 2024 7:58 am
Sorry about the LONNNNNNG delays.... but the blacklist / Friendslist issue should be resolved in latest beta, if anyone wants to try it email 'support at firetrust dot com' and refer to this post.... cheers!
