Mailwasher Update File?
OldNavy
Sun Jul 07, 2024 6:57 am
Running mailwasher pro 7.15.5 on win 11 pro.
For some reason every time mailwasher checks for an update it creates an update.aiu in my downloads folder. It seems to be a history of all mailwasher versions and release dates. It's about 68kb in size
Why is it doing this?
Regards
Sailor
Re: Mailwasher Update File?
Sun Jul 07, 2024 7:02 am
Likely you have your updates folder set to this, check under Settings>>General>>>Updates, try moving to a different folder if you wish....?
OldNavy
Sun Jul 07, 2024 7:06 am
gingbat,
That was it, not sure how it got changed from default (whatever that is).
All sorted now.
Thank you for the prompt response.
Regards
Sailor
Not a problem Sailor! :)
