May I have the sink-sieve tray icon back?
aguen
Fri Jul 16, 2010 7:10 pm
I know, there are much more urgent issues but I liked the old sink-sieve tray icon very much (used to it for many years). It was/is very distinct and highly visible - in contrast to the new soap icon. I managed to change my desktop icon to the old one but would like to see it in system tray too. Is there any hope?
Best,
Armin
...and thank you for this piece of software I am using since many years
Re: May I have the sink-sieve tray icon back?
Fri Jul 16, 2010 10:07 pm
Hi Armin
I'd have to say at this point we probably won't allow that to be altered. The reason is we do have many users who are less savvy, and it's a very easy way for them to distinguish between the old and new versions. if both old and new versions managed to have the same icon we would get some very confused people :)
This is also because we don't recommend they uninstall the old version, those who ask us are being told to simply keep it, but disable it from starting up with Windows.
