Sheesh! It is NOT off topic since I added a sound file to it. That is why I did it in the first place. You could have sent a PM if you felt like that in stead of calling me out in front of everyone! Considering that I have shared a lot here...probably more than anyone...I wanted to know if they had any problems with it/them.stan_qaz wrote:This is really off topic for this thread on sharing sounds, if you want to start one of your own maybe some others will chip in.
Got a custom sound you want to share ?
- Duck
- Active Albatross
Re: Got a custom sound you want to share ?
Sorry you took it that way. I'll leave you alone in the future.
- snollofbone
- highly esteamed croaking frog
First phrase of Cantata nr 15 J.S. Bach -
played on alto flute
graham
graham
- Bach.wav
- JS Bach on Alto flute
- (241.5 KiB) Downloaded 779 times
Courtesy of our Sys Admin, in the style of Mr T. [NSFW]
- Pierre
- Knowledgeable Kea
I am not posting another sound but noticed that Vista and W7 do not have the capability to set the volume level of sound files. It was previously done by sndrec.exe so I have posted a zip file which takes its place. Found it on M$ bulletin boards.
- anniebrion
Does MWP show up in Vista/W7 audio mixer so that you can set the apps audio level separate from the system level?
- Pierre
- Knowledgeable Kea
I just copied some .wav files into a separate folder. Then used 'XM Play' and saved them but added an extra character to the new file eg 'ring.wav' to 'ring1.wav'. Played them back and the volume was lower than the original. The .wav files for the system are located under Windows\Media so you can alter your sound system accordingly.
- rajah45523
Hi all,
Long time since I've been here. Only just found the latest update.
New version is great.
I'm not sure if anyone posted or uses this sound so.... Regs, R..
WIN7-SP1/Intel® Dual Core-2.0GHz/500G HDD/4Gig RAM/550 Watt PSU/Radeon HD 5450/360 Watt UPS/Firefox-20.0-62.0.1/T-bird 2.0.0.24/Snagit-v10.0.1/Mailwasher Pro. 7.12.6.
- TrustFire
This one is my all time favorite . . . . . . .
MWP 7 (ßeta) | Windows 10 LTSC (20H2) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
- redwards
Here is the one I use
- GotSpam.wav
- You Got SPam
- (51.98 KiB) Downloaded 689 times
- snollofbone
Magpie warble
recorded a few days ago
- warbleii.wav
- Australian magpie warble
- (171.95 KiB) Downloaded 698 times
- snollofbone
magpie warble 'normalised'
graham
graham
- warbleii.wav
- sound level jacked up a bit.
- (171.95 KiB) Downloaded 632 times
- cfheinz
- Guardian Gecko
And for you Monty Python fans:
- python.wav
- (48.63 KiB) Downloaded 690 times
Carl Heinz
- Bigman
This is my favourite
(from Dilbert, first episode)
Greetings from Germany
Markus
Markus
