I have a filter from my old version of MW that looks for
doc.scr|doc.pif|mp3.pif|doc.pif|zip.pif|zip.scr|mp3.scr
in the header and
.lnk|.bat|.vbs|.vbe|.jse
in the body of an email. Is this done correctly? It flagged an email that as far as I can tell contains none of these, except for lnk without the leading dot.
AJ
Regex Filter Question
Re: Regex Filter Question
That looks like a regex filter, if it is the dot isn't a search character but a wildcard meaning any character. Replace the . everywhere you really want a dot and not a wildcard with \. and you should have it working right.
http://www.regexlab.com/en/deelx/syntax.htm main page
http://www.regexlab.com/en/deelx/syntax/bas_sesc.htm on the dot
Match any character except newline(\n). Use "\." to match "." itself
- allangjohnson
So the way it was before, 'lnk' preceded by anything at all would trip the filter. Thanks.
