After Cox dropping their email service and migrating our accounts to Yahoo it took some work to get them to work with MWP7 we finally got them working.
Sometime in the past 3 weeks MWP 7.15.5 cannot fetch emails from Yahoo.
There are no errors thrown, just endless attempts to fetch emails with no success.
Is anyone else experiencing this issue. I searched recent posts and didn't see anything with this subject so it might just be me.
Any suggestions?
Richard Grounds
MWP 7.15.5 not retrieving emails from Yahoo accounts
Re: MWP 7.15.5 not retrieving emails from Yahoo accounts
Not seen any other reports of this as yet, however I'd try the below first....
Please delete the problem email account first:
Settings>>Accounts, click the account>>Remove Account.
Click File>>Exit to close MWpro, then re-open it.
Click the Incoming tab and click "Sign in with Yahoo", follow the prompts and you'll be asked for permission to allow MW access to the account, ensure you agree to this.
If incoming does not populate with the correct Yahoo data, ensure it looks like what's showing here:
viewtopic.php?f=13&t=65558&p=177551#p177551
- groundtrooper
Deleting and recreating the accounts solved the problem. Thanks. I wanted that to be the last resort but either way it solved the problem.
Thank you.
Thank you.
Yes, although it sounds drastic, it's often the easiest fix, as it does not effect anything else in MW eg learning, friends/black lists or filters..
Good to hear it helped!
