Emails not displaying
- fyshious
Emails are checked but not displayed on the screen. Event log shows email fetching and filtering was complete.
Re: Emails not displaying
Yes, if the event/error log shows, either there is an error when checking mail, (OR, you have "Settings>>Display>>Event Log, "Always show event log" enabled)
If there is an error, please check your settings for this account within MWPro under, Settings>>Accounts, click your email account then click the "Incoming" tab.
Ensure you have the correct POP3/IMAP server and username entered there, and re-type your password.
NOTE: you can get settings for most ISP's (not personal domains) here: http://www.emailsettings.email/
If this fails, could you please send me your logs as described below:
- Use MWPro until you get an error
- Click "Send Logs"
- Click "Send Logs"
- fyshious
Checked that and sent you the logs. There are 2 email accounts on this and one of them is displaying but not the other. The server address is the same for both
Great, thanks for those logs, and yes, both accounts do actually seem to be working fine... if however one is not showing unread mail that IS on the mail server, I'd recommend that you delete the problem email account first:
Settings>>Accounts, click the account>>Remove Account.
Click File>>Exit to close MWpro, then re-open it.
Click the Incoming tab and click "Sign in with Microsoft", follow the prompts and you'll be asked for permission to allow MW access to the account, ensure you agree to this.
How'd that go?
How'd that go?
