Start here for the MW version of regex: http://www.regexlab.com/en/deelx/syntax.htm
http://www.regexlab.com/en/deelx/syntax/ext_modm.htm
So use a -i to not ignore case and look for (?-i)YAHOO@YAHOO\.COM as a guess.
Filters
Re: Filters
- anniebrion
Re: Filters
I have a similar problem and use this regex:
Code: Select all
(?-i)(^|<|\x20)YAHOO@YAHOO\.COM\b
- Digital Drummer
Ok - thanks. I will try this.
I did find a work-a-round that I believe will work because I just can't grasp this regex thing. Because this sender has a unique return path I made a filter to flag that as good. I'll see if these work in the next day or so.
Re: Filters
anniebrion wrote:I have a similar problem and use this regex:Code: Select all
