anniebrion wrote:You don't have to close MWP!!! You either wait for an auto-fetch to happen or you can manually clear the inbox pressing C the Y then doing a Fetch/Check All.Digital Drummer wrote:Only closing MW and restarting it allows the DL'd messages to be deleted from the MW inbox.
FYI: All versions of MWP (old and new) just read the mail server list there is no interaction between MWP and your email client.
Yes I know there isn't any interaction between MW & my mail program. I only wanted to show whats going on during the process.
So what I'm saying is in v1.0.4 and earlier once my mail was deleted from the server (by my mail program/ thunderbird) an auto-fetch or a manual fetch would erase any/all mail from the MW inbox without pressing any C or Y. It doesn't do that now.
Regardless if C or Y clears the inbox the auto & manual fetch in v1.0.5 no longer clears the inbox when messages no longer remain on the server. Hence, it is a bug and should be addressed.
