Problem deleting email unknown error
gerohl
Sat Jul 31, 2010 5:31 pm
I often get this when I'm deleting email in MV 2010, it just stops. If I close down MW and open it again it works fine. It alaways happens when there ar many emails on the server.
I never had this problem with MV 6
Gert
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>06a8caf38a642ce0cc0e69df0e7dc6fd</ID><DT>2010-07-31 07:18:54</DT><MWPEXCEPTION><UID>Exception 10d36b16c80a1e51dbb8cb35577c776b</UID><AID>Acctxxxxxxxxxx</AID><SOURCE>POPservice::DeleteMessgesForUIDlist</SOURCE><MESSAGE>SocketException - Socket Closed</MESSAGE><ADDXML><TYPE>POPDELETE</TYPE><HOST>treefrog.he.net</HOST><PORT>110</PORT><ACCOUNT_TEXT>xxxxxx_statusquo_com</ACCOUNT_TEXT>
<ACCOUNT>Acct1xxxxxxxxx</ACCOUNT><USER>statusquo.com/xxxxxx</USER><LOGINTYPE>1</LOGINTYPE><SSLMODE>0</SSLMODE></ADDXML></MWPEXCEPTION>
<ORDINAL>0</ORDINAL></EVENT>
Re: Problem deleting email unknown error
Sat Jul 31, 2010 5:49 pm
If you have pipelining enabled for deletes you could try turning that off and see if it helps. If it doesn't turn it back on and after the problem has happened again you could submit your logs to firetrust. Put a link to your post in the comments as well as a short explanation of what is going wrong and use chris as the ticket number to direct the logs to the fellow who watches over the forums.
nobodyspecial
Sat Jul 31, 2010 8:04 pm
It looks like, for some reason, the connection to your Treefrog mail server is closed...
And meant to add, your post displays your user and account details - eek
gerohl
Sat Jul 31, 2010 9:36 pm
nobodyspecial wrote:It looks like, for some reason, the connection to your Treefrog mail server is closed...
It's not closed, if I open MW 6 I can delete them without any problem. I've also tried with pipelining enabled, but the result is still the same.
Thanks for telling me about the account details ;)
Sat Jul 31, 2010 9:41 pm
Can you keep PIPELINING disabled for deletion, and next time it happens go Help >> Send Support Logs >> enter chris as the Ticket Number >> Send Logs >> and I'll take a look
gerohl
Sat Jul 31, 2010 10:53 pm
rusticdog wrote:Can you keep PIPELINING disabled for deletion, and next time it happens go Help >> Send Support Logs >> enter chris as the Ticket Number >> Send Logs >> and I'll take a look
I've just sent you the logs!
Gert
Sun Aug 01, 2010 5:53 pm
Right got the logs, it looks to be related to how MailWasher adds to the Recycle Bin prior to the deletes, it's basically taking too long.
I'll see if we can get this fixed tomorrow.
gerohl
Tue Aug 03, 2010 8:19 pm
rusticdog wrote:Right got the logs, it looks to be related to how MailWasher adds to the Recycle Bin prior to the deletes, it's basically taking too long.
Will you contact me when the problem is solved ?
Gert
Tue Aug 03, 2010 8:32 pm
Yeah I'll try to remember to post here when it's ready
Wed Aug 04, 2010 7:49 pm
OK, here it is. Still the beta, not yet official.....
A new Beta version of MailWasher is now available 1.0.9
Note : This is not an official release, so the Automatic Updater will not pick up this new build.
There is no requirement to uninstall the old version, it will install fine over the top.
Changes Include :
Wash Mail speed improved
Added Notification option 'Play sound when error occurs'
Fix for non ASCII text not being displayed properly
Fix for Check Mail failing on some servers (Tiscali + some others)
Download Link :
http://mailwasherbeta.s3.amazonaws.com/ ... 082010.exe
Kilsally
Wed Aug 04, 2010 10:48 pm
seems to be my problem too as mw6 worked fine - is there a way to turn of the recycling part as i never use it anyhow?
anniebrion
Wed Aug 04, 2010 10:54 pm
I think if you change the "Store deleted mains for" to zero, in Recycle Bin >> General, stops entries to the Recycle Bin.
Kilsally
Wed Aug 04, 2010 11:59 pm
if you are on vista / win 7 this worked for me:-
http://forum.firetrust.com/viewtopic.php?f=50&t=6593
it is to do with administrator rights and permissions
gerohl
Thu Aug 05, 2010 1:44 am
rusticdog wrote:OK, here it is. Still the beta, not yet official.....
Changes Include :
Download Link :
Thanks Chris, I'll download it and let you know if it's works.
Gert
gerohl
Thu Aug 05, 2010 2:31 am
Changes Include :
Download Link :
Chris
It didn't go so well, I've sent you new logs.
- Gert
