Reinstalling Mailwasher and retrieving previous data
Hans L
Sun Dec 08, 2024 6:00 am
Hello:
I uninstalled Mailwasher 7.15.10 in order to troubleshoot my email downloads. It is now fixed.
I reinstalled Mailwasher, and imported file Exported data.mwp. And I see Friend list and Black list in Settings. I ]also have C:\Users\[MY_ID]\AppData\Roaming\Firetrust\MailWasher\cache\MWP.db3.
What I am nor sure about is all the URLs marked Spam and maybe other filters. And I do not have anything in the recycling bin. And, if Import in Settings is involved, I do not really understand the process.
Would be grateful for some aid in recovering what I had before uninstalling.
Thanks,
Hans L
Re: Reinstalling Mailwasher and retrieving previous data
Sun Dec 08, 2024 7:59 am
Hi Hans,
Yes, just import that .mwp file via File>>Import within MWpro and MWPro should be exactly as before you uninstalled....?
Hans L
Sun Dec 08, 2024 1:56 pm
Just that now, it tells me that the file contains corrupted data. Dam, life is not easy!!!
Hans L
Sun Dec 08, 2024 7:32 pm
Hi Hans,
Yes, that's indeed very annoying alright... another option is to try opening it with a .zip file manager (like 7zip for example]) and extract the contents to the folder that opens when you click Help>>User Files within MWpro.
Note, ensure you replace the current files with MWpro closed however.
7zip is here if needed: https://7-zip.org/download.html
