Is there a way to combine mailwasher data files from one laptop and another?
dkodgis
Fri Dec 20, 2024 6:42 am
I use Mailwasher since forever. I have it on one laptop for a number of years. I got a new laptop a year ago and have been using Mailwasher on it. I just realized I could have backed up and transferred Mailwasher's data files from the old laptop to the new one. Now I have several years of Mailwasher data files on the old laptop and a year's work of data files on the new laptop.
Is there a way to combine, merge the data files from the old and new laptops into new files and load those so that all the past data is combined with the new, current data?
Re: Is there a way to combine mailwasher data files from one laptop and another?
Tue Dec 24, 2024 8:10 am
Sorry but no, when you import the settings from another systems MWPro it'll override the current ones.....
Only file you can possibly merge is the filters, however you'd need to copy and paste each filter that is different from the filters.xml file under Help>>User Files in MWPro which would be a pretty slow process.....
