First Alert is no longer is color coded.
ronniejimmy
Thu Jan 02, 2025 5:55 am
I got a virus (3 or 4 of them on two SSDs) and had to reinstall all of windows and upgraded my PC (Intel 12th gen DDR5) in the process.
Now when Mailwasher comes up, it has nothing marked as good or bad. I enabled First Alert and it didn't make a difference.
How do I get Mailwasher to go color coding again.
Thanks for any help in this matter.
Re: First Alert is no longer is color coded.
Fri Jan 03, 2025 9:05 am
Yes, any new installation will require re-training unless you export the settings from the old PC and import these to the new one....
Just mark all as good/friend or spam/blacklist and MW will start doing this itself after a few days...
Cheers!
