MW not opening WLM after washing
- hansi
Since this morning, MW is not opening my WLM programme after washing mail as it did before. I have to click on Mail Program which I didn't have to do before.
- anniebrion
Re: MW not opening WLM after washing
Does the status in the bottom-left of the window say IDLE? If not this is a known bug and you have to hit wash a second time
I've reported this in the beta forum but its way down low on the list to be looked at
- hansi
Yes it does say Idle and also after washing, the emails are not disappearing from the MW window.
- anniebrion
Are you getting a error tab with a blinking triangle? This would stop the wash process completing.
- hansi
- anniebrion
This is indicating an error happened, open the tab to find out what the error is. Opening the tab will stop it blinking also a clean fetch with no errors.
Your mail client will not be opened if there are errors in MWP.
