Can`t restore emails
krazykanuck
Wed Aug 04, 2010 10:23 am
My ISP does not require authentication.
When I attempt to restore an email I get an unknown error
Info from the log is below, some info scrubbed
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>88c54bef2a3d95b13eca66706948da57</ID><DT>2010-08-03 18:14:40</DT><MWPEXCEPTION><UID>Exception 472d2130bcca0dbcccba2b2fad548444</UID><AID>*</AID><SOURCE>MWP_SMTP::SendEmail</SOURCE><MESSAGE>StdException - SMTP failed to que message</MESSAGE><ADDXML><TYPE>SMTPSENDLIST</TYPE><HOST>smtp.isp.com</HOST><PORT>25</PORT><ACCOUNT_TEXT>Restore</ACCOUNT_TEXT><ACCOUNT>*</ACCOUNT><USER></USER><LOGINTYPE>10</LOGINTYPE><SSLMODE>0</SSLMODE><TO></TO><ORIGINAL_FROM>"xxxxxx xxxxxxx" <[email protected]></ORIGINAL_FROM><MAIL_TO>"xxxxxx xxxxxxx" <[email protected]></MAIL_TO></ADDXML></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
I don`t have a problem in 6.5.3
Re: Can`t restore emails
Wed Aug 04, 2010 10:50 am
Check your settings in 2010 against v6, pay particular attention to the Advanced Settings section.
Wed Aug 04, 2010 12:46 pm
krazykanuck wrote:My ISP does not require authentication.
Don't know if you have multiple accounts or not but each message to be restored will use the same account that it originated from with the following exception if the original account fail then there is a means to specify a "fallback account". Settings, Recycle Bin, Restoring, "Fall Back account to restore emails".
Also be aware that some ISP's restrict (as in block) what they think may be spam from being restored.
I would suggest that you may want to check the port number compared to you email application and/or 6.x.
If none of this helps then post your ISP info, create an attempt to restore and then when the error occurs go to Help, Send Logs and use Chris as the ticket number refer to this Topic and a short explanation.
krazykanuck
Wed Aug 04, 2010 3:55 pm
Below are the smtp settings for the two versions.
6.5.3 works just fine
I do have multiple accounts and they are all setup the same
Something I just noticed is that it won't let me setup a fallback account.
The dropdown box is empty.
The popup text says that only accounts with completed SMTP settings can be selected.
I can change the settings and save them so they are being stored somewhere but possibly not correctly.
Wed Aug 04, 2010 4:21 pm
Interesting, it should let you use a server if it has SMTP settings. Check the email address field under the General tab for the account....
If that's also correct, send me your logs. Go Help >> Send Support Logs >> enter chris as the Ticket Number >> Send Logs >> and I'll take a look
krazykanuck
Wed Aug 04, 2010 10:47 pm
That was it.
I didn't realize that you had to enter the email account on the general tab.
My ISP uses the email address as the user name so I saw my email address on the incoming tab and it never occurred to me to enter anywhere else.
Thanks for your help
