MailWasher Pro 2010 Error Message
perro100
Fri Aug 06, 2010 4:22 am
Can anyone help with this? I just bought MailWasher Pro 2010; It's good, I like it, but I keep getting this message:-
Cannot call Arrange on a UIElement with infinite size or NaN Parent of type "System.Windows.Controls.Grid" invokes the UIElement. Arrange called on element of type "System.Windows.Shapes.Rectangle"..
Can anyone tell me what's wrong here, as I'm completely baffled by it?
Many thanks,
johno
Re: MailWasher Pro 2010 Error Message
Fri Aug 06, 2010 9:24 am
perro100 wrote:Hi,
Many thanks,
This error has been mentioned in the New MailWasher Pro 2010 forum. Can I suggest you open up a new thread there.
johno
Sun Aug 08, 2010 4:24 pm
Have moved into appropriate forum :)
Try a repair of .NET. In the Control Panel >> Add/Remove Programs Utility >> look for Microsoft .NET Framework (likely version 3.5) >> select Change/Uninstall >> you should then be prompted and have the ability to Repair instead, run this then reboot the machine. Let us know how you get on.
