How to do a filter for a recurring blank email which I receive frequently. The message has no sender, subject or message and appears as a blank message.
There is a lot of info in the header, but I can't figure what info to put in the filter as sender or domain to blacklist.
The header info is below.
Any suggestions would be appreciated
Thanks,
Bob
X-Apparently-To: [email protected] via 206.190.37.222; Fri, 06 Aug 2010 21:36:58 -0700
X-YahooFilteredBulk: 59.108.53.251
Received-SPF: softfail (mta1010.rog.mail.re2.yahoo.com: domain of transitioning [email protected] does not designate 59.108.53.251 as permitted sender)
X-YMailISG: 4W.MBHccZArCnWOUJ9g7TmS.MtR9U02YfgS9wIxvoacuqiw1
OC2DA06fbMYMW2WaCzgy841LCG_sP2EW92sEck0gmL6zzIMF1mklVYWWBi9_
co001mQyvLH9PgWRUgZKHmE4NX27gP4K0o01N_hqKJB5PAV5CdCoOh9D.cGj
1FbWLf8JPtpynIw1Wo2n.q.CBrITAhXZjqWB9iWSsZGBhzV8phmLuOeZPw1D
bVycnnAVEa7C0p70y8EumOrdTxWrj.Jk.hi5ggRopDtET_kQt1Bqn5.MgDAp
yqZlrP4RdC7ZuRvHl52RrkETks0X2zPsS7.XTahFxh7Z3esrj5eGcRiwXeVi
YdNuamE1TgQ.CwmxmKkhRZljGQINFRtLCZ.qqAnHHdYj9xioMZBcpVl2XXEo
JM.i3Dxzt_hUlokSKVh9wxcU8fCxeYfam43sD_O4VLAapmwaK.CjoAFGPRTN
2wxdMVVGIozLBbRa6LZb0HGnjzclq0KPi4vVqbwCoEuDCOpU6eKU
X-Originating-IP: [59.108.53.251]
Authentication-Results: mta1010.rog.mail.re2.yahoo.com from=; domainkeys=neutral (no sig); from=; dkim=neutral (no sig)
Received: from 59.108.53.251 (HELO 206.190.36.85) (59.108.53.251)
by mta1010.rog.mail.re2.yahoo.com with SMTP; Fri, 06 Aug 2010 21:36:58 -0700
Received: from 133.211.208.144 by 59.108.53.251; Sat, 07 Aug 2010 10:32:04 +0500
Message-ID: <T[20
X-Antivirus: AVG for E-mail 9.0.851 [271.1.1/3055]
Content-Type: multipart/mixed; boundary="=======AVGMAIL-47047A46======="
Re: How to do a filter for a recurring blank email
So there's no Subject line in the header ?
I would probably start there, a simple, if the Subject doesn't contain Regex . <- That's a fullstop to indicate any character.
You could also look at the Received-SPF: softfail
- Sidewinder
- Weary Womble
You can also use the "does not contain" an "@" in the To: or From: fields.
