I know that a | is used for "or" in a regex expression as in yes|no but what is the symbol for "and"?
Thanks.
AJ
regex question - symbol for "and"
- allangjohnson
- anniebrion
Re: regex question - symbol for "and"
Everything that is not an or (|) is an and.
- allangjohnson
That was quick - thanks.
So, if I write
(.+@){10,} [email protected]
that would catch anything that was both sent to ten or more recipients AND was from [email protected]?
AJ
So, if I write
AJ
- anniebrion
The from: test would go in a separate rule and set the rules to ALL instead of ANY.
- allangjohnson
That's what I was hoping to avoid, because I wanted that filter to be one line in a multiline filter that would be tripped in ANY condition was satisfied.
AJ
AJ
- anniebrion
It's difficult testing to: & from: in the same single rule as I have tried to do this in the past
The major issue is that email headers are not standardized enough, sometimes the to: comes before the from: other times it is the reverse, also sometimes a subject: is inbetween and sometimes not
- allangjohnson
I understand. But am I correct that just putting a space between the two items makes it an "AND"?
So, using a different example, if the filter looks in the subject line for
hot cold
it would trip only if the subject line contained both words?
AJ
hot cold
AJ
- anniebrion
NO putting a space is not an AND.
The and is ie:
"1 or more characters" AND @ AND domain
(fred OR fred) AND @ AND domain
The and is ie:
Code: Select all
.+@domain
Code: Select all
(fred|bert)@domain
- allangjohnson
Sorry to be so slow, but why isn't
(fred|bert)@domain)
(fred OR fred) AND @ AND d AND o AND m AND a AND i AND n?
AJ
(fred|bert)@domain)
AJ
- anniebrion
It is but I couldn't be bothered to do all the ANDs
and it looks tidier than:
"1 or more characters" AND @ AND d AND o AND m AND a AND i AND n
Or
((f AND r AND e AND d) OR (b AND e AND r AND t)) AND @ AND d AND o AND m AND a AND i AND n
The last one makes the AND and ORs harder to spot.
Or
- allangjohnson
So there isn't a way to have a single line that trips a filter if the subject line contains
hot AND cold
AJ
hot AND cold
AJ
- anniebrion
Post .* = Zero or more characters
\x20 = Space
Yes there is but they have to be in the right order or you will need 2 rulesallangjohnson wrote:So there isn't a way to have a single line that trips a filter if the subject line contains
hot AND cold
AJ
Code: Select all
hot\x20.*cold
Code: Select all
cold\x20.*hot
\x20 = Space
- allangjohnson
or could it be in a single line as
hot.*cold|cold.*hot
AJ
hot.*cold|cold.*hot
AJ
- anniebrion
Mabye:
But I'm sure you get the idea.
Simplistically yes, but that would match subject = "Hotdogs and coldfish"allangjohnson wrote:or could it be in a single line as
hot.*cold|cold.*hot
Mabye:
Code: Select all
hot(\x20|$).*cold(\x20|$)|cold(\x20|$).*hot(\x20|$)
- allangjohnson
