Include mail in Junk folder when checking mail
Hanktheone
Sat Feb 08, 2025 2:04 pm
Is and how to have mail that goes to Junk folder be included when MailWasher checks the inbox.? Thank you. Hank.
Re: Include mail in Junk folder when checking mail
Sat Feb 08, 2025 2:21 pm
Yes, MW can only see other folders than the inbox folder when it checks mail on your ISPs mail server if you setup the email account as IMAP as opposed to POP3 type.
If you try this and have any problems, check that your ISP supports IMAP, and if so, but still issues, please get back to me...
IF not already using IMAP, (currently using POP):
Change the IMAP server to what your ISP recommends.
(NOTE: you can get settings for most ISP's (NOT personal domains though) here: http://www.emailsettings.email/ )
Click save to save changes, then select the IMAP tab, click Refresh, and choose your spam or junk mail folders to show in MWpro.
If already using IMAP:
In MWpro click Settings>>Accounts, click your email account, click the IMAP tab, click Refresh, and choose your spam or junk mail folders to show in MWpro.
Hanktheone
Sun Feb 09, 2025 9:09 am
Thank you, Now just waiting for Junk email.
wtpeters
Sun Feb 16, 2025 2:19 am
My mail server puts what it thinks is spam in the Junkmail folder. Mailwasher is not filtering Junkmail. It should filter both 'Inbox' and 'Junkmail'.'
