Conflict with Google Earth
Paphian
Wed Aug 11, 2010 12:14 am
It appears that the new Mailwasher Pro, when installed on Windows XP at least, conflicts with Google Earth. If Mailwasher Pro is running in the background, Google Earth fails to load in DirectX mode and loads, but painfully slowly, in OpenGL mode. Close Mailwasher Pro and it opens promptly and completely in either mode. This is repeatable so that it become necessary to close Mailwasher Pro whenever I wish to use Google Earth.
This never happened in the older versions and is clearly attributable to the greater use of graphics in the new version. If this isn't fixable, I will have to revert to the older version :( Any ideas?
anniebrion
Re: Conflict with Google Earth
Wed Aug 11, 2010 12:28 am
I have not found this to be a problem with Windows 7 or XP sp3 here running in DirectX mode.
Are your Graphics Drivers up to date?
BTW, I'm running Google Earth 5.2.1.1329 (beta) & MWP 2010.1.0.11 (beta)
Paphian
Wed Aug 11, 2010 1:16 am
Same version of Google Earth (updated today in an attempt to fix the problem). Video drivers are up to date and work correctly with a raft of other software. Mailwasher is registered version 2010.1.0.10. I have submitted a bug report.
