Starting tutorial
dfsmetsfan
Starting tutorial
Thu Aug 12, 2010 2:09 am
I'm a long time MW user. The starting animation is great for newbies, but I want it off. I can't get it to uncheck to show at startup. It does nothing when I click on it. I remember having this problem a while back with a different version, but can't remember what to do to shut it off. Any help will be appreciated.
Re: Starting tutorial
Thu Aug 12, 2010 2:16 am
That would be annoying.
Go Help >> User Files >> then close MailWasher so it's not running >> open the startup.xml file in Notepad, you should be able to do this by holdingdown Shift and right clicking the file >> select Open With >> ...then choose Notepad.
Look in the file for this line, it should be almost at the very bottom
Code: Select all
  <PlayAnimationOnStartup>True</PlayAnimationOnStartup>
and change the True to False
Code: Select all
  <PlayAnimationOnStartup>False</PlayAnimationOnStartup>
Start MailWasher...
dfsmetsfan
Thu Aug 12, 2010 7:09 am
Thank you so much Rustic Dog. I knew it was somewhere. All better now. :bow :D
