FiltersPreview error
daverap
Sat Aug 14, 2010 1:19 am
When running MWP after installing I get the following error, and the program doesn't load. Any ideas?
Gracious thanks, David
Cannot create instance of 'FiltersPreview' defined in assembly 'MailWasherPro, Version=1.0.10.0, Culture=neutral, PublicKeyToken=null'. Exception has been thrown by the target of an invocation. Error at object 'System.Windows.Controls.Grid' in markup file 'MailWasherPro;component/spamtoolsidebar/spamtoolsidebar.xaml'.
Re: FiltersPreview error
Sat Aug 14, 2010 1:41 am
Hi there
You want to delete your Startup.xml file.
It will be in either this folder for Vista/Win7
C:\Users\[username]\AppData\Roaming\Firetrust\MailWasher
or on XP
C:\Documents and Settings\[username]\Application Data\Firetrust\MailWasher
daverap
Mon Aug 16, 2010 7:40 am
Thanks! It's now working.
The XP path for me was:
C:\Documents and Settings\[user name]\Application Data\Firetrust\MailWasher
I installed the Beta but wasn't happy but I'm very hopeful that now I'll like what I find.
Thanks to the MW team for all their hard work.
Mon Aug 16, 2010 1:14 pm
No problems, we're making improvements all the time as well :) Hopefully another version this week sometime.
