Copy / Clipboard error
molasses2
Sat Mar 15, 2025 5:09 am
I'm using Spamcop to report spam, but having trouble getting it to work, so I decided to report manually by copying the source code and submitting directly. Every time I select the full source and copy, I get this error...
OpenClipboard failed exception from HRESULT 0x800401D0 CLIPBRD_E_CANT_OPEN
...and MailWasher crashes.
A short Internet search indicates this is a known issue with .NET 4.0 (and beyond, apparently). I'm hoping for a fix.
In the meantime, I've found a super clumsy workaround - select and copy one single character, then select all and copy again.
Re: Copy / Clipboard error
Sat Mar 15, 2025 11:28 am
Yes, please update to 7.15.20 from here:
That should stop that error....?
molasses2
Tue Mar 18, 2025 4:17 am
Thank you! Yes, it seems to have fixed things for me.
