Regression: Cannot view HTML version of Postmark emails.
kikosoft
Mon Mar 17, 2025 12:21 am
For quite a while now I've been unable to view https://postmarkapp.com/ emails in the HTML format in MailWasher Pro. The version I'm using now is 7.15.20.
I have reported this problem before, and it was solved in version 7.12.120. See: viewtopic.php?f=50&t=54467
Can this problem be solved again? Emails often do not contain a plain-text version, so I cannot read them in MailWasher Pro at the moment.
I can support the debugging process, just email me.
Minor other problem, with the https://www.mailwasher.net/ website: A lot of the links in the top menu bar do not work. I guess this site was somewhat neglected in favor of the newer https://firetrust.com/ site?
Re: Regression: Cannot view HTML version of Postmark emails.
Mon Mar 17, 2025 1:10 pm
Yes, 'should' be resolved for most in the current beta, hoping for a full release any week now....!
If problems persist however, you are welcome to email support at firetrust dot com referring to this post and we can send you the beta to try.
Cheers!
kikosoft
Mon Mar 17, 2025 11:50 pm
Thank you, I'll await the next full release. I'm not sure if that will be version 7.16 or 8.0, but I'll see what happens with the next update... As long as a fix is in the pipeline.
kikosoft
Sat Apr 12, 2025 1:11 am
I just updated to MWP 7.15.33 and can confirm that this problem is solved.
Sat Apr 12, 2025 7:43 am
Cool... thanks for letting us know!
