7.15.33 and Gmail
genegold
Guardian Gecko
7.15.33 and Gmail
Sat Apr 12, 2025 10:26 am
Installed the update, but first I got a big popup for allowing Gmail. One of the things asked was, as I understood it, allowing them to read, delete, etc., my Gmail. I didn't check that box. Since then, I've been get lots of Gmail errors, as attached, when I Wash Mail. It says to try authentication again, but how does one do that and is checking the box necessary (or did I misunderstand)? Thanks,
Mailwasher Google.JPG (11.59 KiB) Viewed 645 times
Re: 7.15.33 and Gmail
Sat Apr 12, 2025 12:07 pm
Yes, please see this post for how to setup gmail:
viewtopic.php?f=50&t=71020
Let me know if any issues?
genegold
Guardian Gecko
Mon Apr 21, 2025 8:20 am
So Mailwasher (or Google?) threw up the same process for confirming MWP's access to Gmail for the second time this week, the first being the initial set up. Do you know if this going to be frequent?
Mon Apr 21, 2025 9:22 am
Yes, is usually only a one off, possibly however the authentication got disabled or removed somehow?
If it keeps happening, ensure you don't have any disk cleanup software installed that is clearing some of MW's user files or something like that?
If so, set it to ignore any folders listed under Help>>User Files within MWPro....
