Trouble running MWP2010 1.0.15 installer
Daledoc1
Guardian Gecko
Thu Aug 19, 2010 3:11 pm
Figured I'd start a new thread, since my issue differs from that of the OP on the other thread about filters/settings not importing from 6 to 2010.
Can't run installer for MWP2010 1.0.15.
Laptop: Check for updates tells me I am UTD. So, I download the installer from the link in RD's sticky at the top of the forum page.
Closed MWP.
When I try to run it, I get a "not a valid Windows application" (or some such) error.
Not a permissions thing from UAC.
Am I just brain-fried, or is there something I am doing wrong, or is there a problem with the file?
Do I need to have MWP **open** to run it?
(I thought one usually has to **close** a program in order to install updates??)
Thanks,
daledoc1
DT1: Win10-Pro/64; Fx, TB; MWP 7.8.0; MSGTAG; KIS2016.
DT2: Win7-Ult/64 SP1; Fx; TB; IE; MWP 7.8.0; MSGTAG; KIS2016.
LT: Win7-Pro/64 SP1; Fx; TB; MWP 7.8.0; MSGTAG; Sophos.
MBAM & MBAE Premium & SAS Free for all.
Re: Trouble running MWP2010 1.0.15 installer
Thu Aug 19, 2010 3:16 pm
First step try the download again, hopefully it will work then. I'd close MW to do the upgrade install but it will close MW if it finds it open so either way should work.
If that isn't it I'd guess Windows issue of some type and I'm little help there.
Daledoc1
Guardian Gecko
Thu Aug 19, 2010 4:13 pm
Does downloading and running from that link in the sticky note work for you?
It looks like it downloaded 2 files, the ".exe" and a ".exe.part" file, which seems weird.
I can't imagine what "Windows" thing could be causing the error. The computer is otherwise fine and stable, fully patched, yadayada.
Total computer noob here, but the problem seems to be with the executable file?
Well, will wait to hear back, perhaps from RD, before trying again on either system.
Thanks and g'night,
daledoc1
Thu Aug 19, 2010 4:19 pm
If you are seeing an exe and an exe.part it is because your downloader has not finished downloading the file, you have to wait for it to finish before using it.
It is Windows... I can imagine a dozen things that could be going wrong, why I quit using it myself.
Daledoc1
Guardian Gecko
Thu Aug 19, 2010 11:30 pm
Hmm, OK.
Well, it appears I'm not the only one having this problem, as there is another thread started by another poster.
The LT is powered off and I will be leaving for work soon, so I will try again later on it, on this DT, or on both...
(Pending help from RD and others.)
THANKS, Stan_gaz!
Daledoc1
Guardian Gecko
Fri Aug 20, 2010 12:48 pm
1.0.15 successfully manually downloaded and installed on both systems. :)
RD was correct, as usual: it must have been a corrupt download the first time.
(FWIW, the updater must be wonky, b/c I tried "help" > "check for updates" on both systems immediately before, and was told I was UTD.)
If 1.0.15 includes an updater fix, then I hopefully when the next build is released, the same steps WILL notify me that an update is available? :?:
Thanks!
daledoc1
Fri Aug 20, 2010 12:57 pm
We've fixed everything we can think of with the updater, so fingers crossed it's all good for next time
vk4apn
Fri Aug 20, 2010 1:26 pm
I cant get the "mailwasher_pro_setup_1015_18082010.exe" installer to work on my PC.
I am running XP with all updates, also checked the .net SP as per upgrade instructions to be sure.
I have downloaded file twice and run from desktop, also run directly from download. I have restarted the computer between each try.
I get an initial box preparing to install - then nothing, the task mamager shows 100% Load, I have left for over 15 minutes on each occasion - it does not proceed.
Task manger shows it the installer as running.
? Paul
Fri Aug 20, 2010 5:51 pm
vk4apn wrote:I cant get the "mailwasher_pro_setup_1015_18082010.exe" installer to work on my PC.
? Paul
Hi Paul
Was there any previous MailWasher 2010 installed, or is this the first time you've tried to install ?
vk4apn
Fri Aug 20, 2010 6:56 pm
? Paul
Hi Paul
First time install for 2010 - am currently using V6.51
budnick
Sat Aug 21, 2010 4:52 pm
Hello.
I cannot install the latest version as the installer asks for the MailWasher disk. I have no disk as my MWP 2010 was directly down loaded.
I currently have version 2010.1.0.6 installed.
Any suggestions?
Thanks.
Budnick
Sat Aug 21, 2010 5:08 pm
budnick wrote:Hello.
Any suggestions?
Thanks.
Budnick
Hi Budnick
Try removing 1.0.6 through the Control Panel >> Add/Remove Program utility >> be sure though to answer Yes, to keep your data files >> then try installing 1.0.15 manually again.
Pierre
Did you click on 'Help' and then 'Check for update' ?
Darn, beaten again.
Sat Aug 21, 2010 5:14 pm
Pierre wrote:Did you click on 'Help' and then 'Check for update' ?
Darn, beaten again.
It was worth the extra post, I get mesmerised by your avatar :)
budnick
Sun Aug 22, 2010 2:25 am
Hello.
I was able to get it to work by uninstalling. Was not able to uninstall using "Control Panel >> Add/Remove Program utility >> " had to use Revo Uninstaller as it was still looking for Disk1.
New version working fine now.
Thanks.
Budnick
