Checking mail when switched out
preader
Sat Aug 21, 2010 6:17 am
I often "switch user" out of my admin account but leave the computer on because there is another user. I just installed the new version of Pro, and it looks to me that the periodic default check does not take place if my account is switched out; when I log back in, no new posts appear until I hit the check-mail icon. Is this by design? The old version did check mail even tho my account was switched out. Running Vista Home Premium.
Peter
Re: Checking mail when switched out
Sat Aug 21, 2010 6:33 am
Hi Peter
Yes this is by design. If I recall correctly, if MailWasher is set to check at startup, when you return to the other account it should fire a check automatically, even though it technically hasn't started.
preader
Sat Aug 21, 2010 8:16 am
Thanks....
It doesn't look like the default check fires when I return from being switched out...I'll see if it does when I log back in from a logout.
preader
Sun Aug 22, 2010 2:04 am
Well, MWP doesn't fire the startup check when switching back in, but it does when logging in from a logout. I guess I can live with that....
Peter
Sun Aug 22, 2010 5:11 pm
preader wrote:Well, MWP doesn't fire the startup check when switching back in, but it does when logging in from a logout. I guess I can live with that....
Peter
We can alter that behaviour if you think it would be better ?
preader
Sun Aug 22, 2010 5:34 pm
Well, seems like it would be consistent to treat both situations the same way. Actually, what would be cool would be if MWP stayed running (and checking mail) during a switchout (but not a logout). That way, when switching back in, you'd immediately see your incoming mail rather than waiting for the ISP to download the headers...
Peter
Sun Aug 22, 2010 7:52 pm
preader wrote:Well, seems like it would be consistent to treat both situations the same way. Actually, what would be cool would be if MWP stayed running (and checking mail) during a switchout (but not a logout). That way, when switching back in, you'd immediately see your incoming mail rather than waiting for the ISP to download the headers...
Peter
We'll do the first, as I know that will just be a quick logic alteration. The second requires some more serious thought given we have both User Interfaces and the Engine running as separate processes.
preader
Mon Aug 23, 2010 2:28 am
Cool! Thanks, guys....
Peter
