The program doesn't start
guakamole
Mon Aug 23, 2010 2:41 am
The program doesn't start, each time there appears a box with the message "Cannot create instance of 'MWPMainWindow' defined in assembly 'MailWasherPro, Version=2010.1.0.15, Culture=neutral, PublicKeyToken=null'. Exception has been thrown by the target of an invocation. Error in markup file 'MailWasherPro;component/MWPMainWindow.xaml'.
What could be done about it?
anniebrion
Re: The program doesn't start
Mon Aug 23, 2010 2:45 am
Try repairing .net 3.5 in Add/remove programs.
guakamole
Mon Aug 23, 2010 8:33 am
Thanks for the advice but it didn't help... Now I have the latest .Net 4 but the prog still doesn't work :no
Mon Aug 23, 2010 9:01 am
guakamole wrote:Thanks for the advice but it didn't help... Now I have the latest .Net 4 but the prog still doesn't work :no
MWP is not using .Net 4 at this time.
Mon Aug 23, 2010 9:03 am
This sound to me like you may have a bad download copy. Try to uninstall MWP from the Control Panel. Download a fresh copy of V.15 and try a new install.
nobodyspecial
Mon Aug 23, 2010 9:04 am
Make sure you have .net 3.5 SP1 installed. If you do - try repairing it through the control panel.
guakamole
Sat Aug 28, 2010 6:12 am
I'm actually not able to repair .net 3.5 - I'm on Windows 7 and can only switch it on or off through "Turn Windows features on and off", which I tried more than once (together with more playing around with various versions of .net), but to no avail. The problem repeats itself with the latest version too...
Mon Aug 30, 2010 1:40 am
guakamole wrote:The program doesn't start, each time there appears a box with the message "Cannot create instance of 'MWPMainWindow' defined in assembly 'MailWasherPro, Version=2010.1.0.15, Culture=neutral, PublicKeyToken=null'. Exception has been thrown by the target of an invocation. Error in markup file 'MailWasherPro;component/MWPMainWindow.xaml'.
You first probably want to just put 1.0.19 over the top, just in case http://www.firetrust.com/products/mailw ... 0/download
If the problem persists let me know and we'll see about getting some log files to try and determine the fault.
guakamole
Mon Aug 30, 2010 3:54 am
Thanks for trying to help. Yes, the problem persists; the pop-up Net Framework error box gives the following info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at System.Windows.Forms.NotifyIcon.ShowContextMenu()
at System.Windows.Forms.NotifyIcon.WndProc(Message& msg)
at System.Windows.Forms.NotifyIcon.NotifyIconNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MailWasherPro
Assembly Version: 2010.1.0.19
Win32 Version: 2010.1.0.19
CodeBase: file:///C:/Program%20Files/FireTrust/MailWasher/MailWasherPro.exe
System
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
MWP_API
Assembly Version: 9.0.6.1
Win32 Version: 9.0.6.1
CodeBase: file:///C:/Program%20Files/FireTrust/MailWasher/MWP_API.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.4926 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
Xceed.Wpf.DataGrid
Assembly Version: 3.7.10308.14440
Win32 Version: 3.7.10308.14440
CodeBase: file:///C:/Program%20Files/FireTrust/MailWasher/Xceed.Wpf.DataGrid.DLL
Xceed.Wpf.Controls
CodeBase: file:///C:/Program%20Files/FireTrust/MailWasher/Xceed.Wpf.Controls.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data.DataSetExtensions
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Data.DataSetExtensions/3.5.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationTypes/3.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Xceed.Wpf.DataGrid.ThemePack.1
CodeBase: file:///C:/Program%20Files/FireTrust/MailWasher/Xceed.Wpf.DataGrid.ThemePack.1.DLL
PresentationFramework.Luna
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
System.Data.Entity
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Data.Entity/3.5.0.0__b77a5c561934e089/System.Data.Entity.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Mon Aug 30, 2010 3:59 am
OK great. Could you also email me your error.log file, which will be in
C:\Users\[username]\AppData\Roaming\Firetrust\MailWasher\
And also if possible a zipped copy of the Logs subfolder in the same location. Alternatively you could just remove your accounts.xml file and zip and email me the whole MailWasher folder....
If you send to [email protected]
Many thanks.
guakamole
Mon Aug 30, 2010 5:24 am
... oops, stupid me, I should've been more diligent and made a really clean uninstall before starting to complain. Now, as the last pot-shot at the problem, I deleted the folder you indicated (C:\Users\[username]\AppData\Roaming\Firetrust\MailWasher) and oh my the program works! Sorry for the bother and thanks for guiding me in the right direction! :D
Mon Aug 30, 2010 4:13 pm
guakamole wrote:... oops, stupid me, I should've been more diligent and made a really clean uninstall before starting to complain. Now, as the last pot-shot at the problem, I deleted the folder you indicated (C:\Users\[username]\AppData\Roaming\Firetrust\MailWasher) and oh my the program works! Sorry for the bother and thanks for guiding me in the right direction! :D
OK great, glad it's sorted :thumbsup but for the record you shouldn't need to do a full uninstall. It would have been a bad file or setting of some kind preventing the startup, so if this problem comes back, just rename the folder instead of deleting. That way if need be we can get a copy of the info to try and determine what might cause this and how we can prevent in future.
