Change icon to previous version?
Lysdexic
Tue Aug 24, 2010 6:36 pm
I am so used to the old icon in the SysTray I am confusing the new icon with Outlook. I would like to change the icon to the V 6.0 icon but can find no *.ico files in either version. Is it possible? Great programme.
Re: Change icon to previous version?
Tue Aug 24, 2010 7:00 pm
Under Settings >> General >> Notifications >> you can set MailWasher to use a different icon in the system tray. There's no way to change the icon to a custom one at present.
Lysdexic
Tue Aug 24, 2010 8:35 pm
Not in my version is there an option to change the icon unless you mean the ability to make the icon blink?
Tue Aug 24, 2010 8:52 pm
Ah right, all you can do is change the icon that triggers when you have new mail, not the idle icon. I would like to add another but we'd also want to avoid making it too similar to the old one in case it confuses folk.
