[SOLVED] Can't launch OE
Maureen
Wed Aug 25, 2010 10:51 pm
Hi to All
Just upgraded to the latest MWP and initially it asked to choose which mail program to use. I use Tiscali but it had 2 entries of the same ISP and so I put a tick in just the one.
I sent a test email to myself and it arrived OK in MWP but when I clicked on MAIL PROGRAM it doesn't open OE. I reinstalled MWP but nothing's changed.
If I completely uninstall it, I will lose any settings.
Please help?
Kindest regards
Maureen
Remember the Universal 'Law of Attraction'. You attract into your life that which you want, or fear the most!!
Re: Can't launch OE
Wed Aug 25, 2010 11:00 pm
Hi Maureen
Under Settings >> General >> Washing Mail >> is Outlook Express selected in the drop down list ?
If not try setting this >> Save >> then see if that works.
Maureen
Re: Can't launch OE
Fri Aug 27, 2010 12:40 am
Hi there,
Hadn't realised you replied. Thing is, I have in the meantime uninstalled MWP!! Sorry!! Will try again and come back to you.
Many thanks x x
Maureen
Re: Can't launch OE
Fri Aug 27, 2010 12:49 am
When I uninstalled the 2010 version, I didn't go via Add/Remove but used the uninstall, which I rarely do. It seems it's still on there!!
Anyway, checked the settings and there is definitely a tick in the boc to Launch email Program after Washing Mail.
Not sure what the problem is really. I suppose I could completely remove the old MWP first and then the new one BUT I'll have to do all my settings.
anniebrion
Re: Can't launch OE
Fri Aug 27, 2010 12:52 am
The old MWP has no affect over the new one they don't share any resources so deleting the old one will achieve nothing constructive.
Rusticdog was asking if OE was in this list:
Re: Can't launch OE
Fri Aug 27, 2010 12:55 am
And is Outlook Express selected as the mail program to open under Settings >> General >> Washing Mail ?
Maureen
Re: Can't launch OE
Fri Aug 27, 2010 12:57 am
Oh, I see. I just wanted to revert back to the old one for the time being.
I've just had a look in Add/Remove and see I have two icons sitting there. I suppose it's OK to remove one of them? It's taking up valuable space!
Maureen
Re: Can't launch OE
Fri Aug 27, 2010 1:00 am
Yes, I have just removed the old one and all seems to be OK now x x
PS: Is there anywhere I can mark this post SOLVED?
Many thanks
Maureen
anniebrion
Re: Can't launch OE
Fri Aug 27, 2010 1:06 am
Just edit your first posts subject in this thread :)
Re: Can't launch OE
Fri Aug 27, 2010 1:07 am
anniebrion wrote:Just edit your first posts subject in this thread :)
Just did it for you Maureen :) Glad it's working now
Maureen
Re: [SOLVED] Can't launch OE
Fri Aug 27, 2010 1:11 am
OK, THANK YOU very much for all your help x x x x
