I have recently installed MW and when I wash the mail it sends the junk to the bin and downloads the good mail to My Outlook folder.#
However after downloading the good emails they remain on the server, I know I must need to tweak a setting for it to remove the emails from the server after download but I can't find it can anyone help.
I'm running Windows 7 with IE8 and Microsoft office 2010
Doug
Emails remaining on MW after download
- anniebrion
Re: Emails remaining on MW after download
This is outlook that need settings changed, IIRC by default OL2010 leaves copied of the email on the server and you have to switch this option off manually within OL2010.
I could be wrong as I don't have Outlook 2010 installed, but that setting to leave emails on the server ought to be
Tools, Account settings, Change, More Settings, Advanced
- gemandy
Thanks for the quick responses but I can't find how to switch it off in outlook 2010
I cant even find the tools option, this is a very new machine and still working my way around it , can you please help
Doug
Doug
- anniebrion
Try this link it should point you at the correct location: http://www.slipstick.com/mail1/leaveonserver.htm
If that don't help try: http://www.google.com/search?q=outlook+ ... =firefox-a
- Sidewinder
- Weary Womble
Here is a link regarding where to find all the Outlook settings:
http://www.howto-outlook.com/faq/locatefeature.htm
- lewcock
If running Eudora do as follows:Click TOOLS,OPTIONS,INCOMING MAIL, leave 'leave mail on server'blank.
All MW mail then clears when dowloaded to Eudora.
- racker
- Knowledgeable Kea
If you have more than one acount, repeat this for each account. "Et voila" as the french say...
In outlook do this: EXTRA>>ACCOUNTS(select account)>>PROPERTIES>>ADVANCED>>(uncheck "leave copy on server...")gemandy wrote:
Doug
Beta tester.. oh well! ..
MWP FAQ
MWP FAQ
