Registration Key Invalid
- aquariusal
I had purchased Mailwasher and had a registration key. I just installed MW 2010.15. When I use my old registration key I get the message that it is invalid. What is my problem
Re: Registration Key Invalid
v6 and 2010 use different keys, if you just purchased v6 and upgraded to 2010 they should send you a new 2010 key, I'd contact support with your MW registration info for v6 and ask for a 2010 key.
Hi there
This version isn't a free update from the MailWasher you had, I'll email you a link as it would seem you didn't get the newsletter..
