Hi
I followed your instructions and did a check updates and it said software up to date and I was using the .15 version and to update had to follow the link, Seems that the message regarding it should work now has not worked for me.
On a more general note, I like many others have had the odd problem with MW2010 but want to say its settled down a lot now and the admins who reply to the posts and those members who update the programme should be thanked for all the hard work and for trying to please All of the people ~~ All of the time
Kindest regards
Updtate to .19 version
- mkcomputing
Re: Updtate to .19 version
Have you looked at the other messages here on this topic?
http://forum.firetrust.com/viewtopic.ph ... 75&start=0
Perhaps you were thrown because they have correct spelling of update.
MK
MW 2010.1.0.42 + Outlook 2007
Windows 7 Home Pro | Outlook 2007 | AMD Athlon 64 X2 Dual Core 5400+ | 4.0 GB Memory | NVIDIA GeForce 8600 GT
