In the previous MWP, and the email clients I've used, it's possible to accept an SSL certificate which wasn't signed for the domain the email address belongs to (may be under the host's domain for example). I can't find a way of doing that with the new version, but would very much like to be able to. Is this possible?
Thanks!
Can't use SSL with invalid certificate
I don't believe we've catered for this. If you enable Protocol Logging under Help, then make the failures occur, then go >> Help >> Send Support Logs >> enter chris as the Ticket Number >> Send Logs.
Re: Can't use SSL with invalid certificate
atom wrote:In the previous MWP, and the email clients I've used, it's possible to accept an SSL certificate which wasn't signed for the domain the email address belongs to (may be under the host's domain for example). I can't find a way of doing that with the new version, but would very much like to be able to. Is this possible?
Thanks!
- atom
Great, thanks for the test account too
For what it's worth in the interim, MailWasher is using APOP by default so your username and passwords to this server are being sent using a challenge response system and not sent in Plain Text when logging into the incoming.
For Outgoing the server supports CRAM-MD5 for authentication so you could set this too.
- atom
