Running a large widescreen monitor on high res find:
1] the thumbs up/down icons are a bit small & close together, often hit the wrong one. Bigger buttons, spaced apart or just single control that changes states
2] Would prefer a right vertical option for the preview pane (like Outlook has) as would allow the email list to be longer reducing scrolling
UI Suggestions
- anniebrion
Re: UI Suggestions
2: Look in "Quick display" >> "Layout" the first icons second option is for RHS preview
Re: UI Suggestions
At some point we'd like to have some different icon sizes for this, hopefully we'll be able to do this some point soon. Have you increased the font size in MailWasher at all, or use Large fonts in Windows ?robincapper wrote:Running a large widescreen monitor on high res find:
Re: UI Suggestions
On the size issue I'm going the other way, I have my text size fairly small and the classification icons (trash and attachment too) are too tall, they won't let the grid lines shrink down to fit the text. Only solution I see to make all happy is offering the multiple size option rusticdog mentioned.
