Hello,
I'm new to MailWasher Pro 7. I have a question. How can I permanently remove / disable the Event Log tab? Please guide me.
Thanks in advance!
How to permanently disable the Event Log tab
- allanpaterson
Re: How to permanently disable the Event Log tab
No way to prevent it appearing if you get an error, however if it shows all the time with no errors in it, you may have "Always show event log" checked under Settings>>Display>>Event Log....?
