Spam and blacklist
Colombe
Spam and blacklist
Thu Sep 02, 2010 8:31 pm
I'm using MWP 2010 1.0.15 for some time now. I marked lots of e-mails as spam and/or added them to my blacklist. Still they appear as possible spam. In MWP 6.51, which is still running on my pc, they appaear as spam! For exemple e-mails who come from [email protected].
Is there any reason for this?
Thanks for your reactions.
anniebrion
Re: Spam and blacklist
Thu Sep 02, 2010 8:39 pm
v6 stops testing tools when one tool triggers a rating, MWP2010 takes all tools into consideration before it rates an email.
See here: http://forum.firetrust.com/viewtopic.php?f=50&t=7214
Colombe
Thu Sep 02, 2010 8:48 pm
So I would say that MWP 2010 is better than V6. But on the contrary, emails from a domain who is in my blacklist appear as good or possible spam!
anniebrion
Thu Sep 02, 2010 8:54 pm
Settings >> Spam Tools >>> Spam Ratings >> Blacklist
Change the value nearer -200, if that is not enough you can also create a simple filter with a "Spam Tool Rule" = "Sender is on my blacklist" and add even more to the spam score and even dictate the deletion behaviour.
Thu Sep 02, 2010 8:57 pm
Colombe wrote:So I would say that MWP 2010 is better than V6. But on the contrary, emails from a domain who is in my blacklist appear as good or possible spam!
The new MailWasher only has Good or Spam, so not sure what the Possible Spam is. But what' you're seeing is a contradiction where the Learning thinks the email is good, the Blacklist says otherwise. If you keep correcting MailWasher in the Classify column as required it'll get better :)
Colombe
Thu Sep 02, 2010 9:31 pm
I'm sorry, you're right it there is no possible spam anymore. But why isn't it marked as blacklist when the sender is blacklisted? Or as spam even after a few weeks of marking the sender as spam?
anniebrion
Thu Sep 02, 2010 9:38 pm
Go to the View menu and select Side Bar this will show you the Spam values for each tool so you can see why the spam total is not coming out >+49
Colombe
Thu Sep 02, 2010 11:19 pm
I don't understand what you're trying to tell me. I didn't change anything in the default configuration, so you would say that it should work properly.
anniebrion
Thu Sep 02, 2010 11:32 pm
I'm telling you to display the Spam scores for the spam tools so you can see what is determining the ratings.
As i already mentioned above, reading this might help: http://forum.firetrust.com/viewtopic.php?f=50&t=7214
Colombe
Fri Sep 03, 2010 5:24 pm
I read the advised topic and understand now a bit how it all works. Now I have set al the Spam Ratings at -200. And even then emails from senders/domains in my blacklist won't appear as blacklisted. I stll can't understand why.
Fri Sep 03, 2010 5:25 pm
Colombe wrote:I read the advised topic and understand now a bit how it all works. Now I have set al the Spam Ratings at -200. And even then emails from senders/domains in my blacklist won't appear as blacklisted. I stll can't understand why.
If the Status doesn't show as Blacklisted, what does it say when you are sure the address is on the Blacklist ?
Colombe
Fri Sep 03, 2010 5:40 pm
It's empty
Fri Sep 03, 2010 5:47 pm
Colombe wrote:It's empty
Well that means the blacklist isn't matching. Oh, and now everything falls into place and I realise I'm a <expletive deleted> idiot.
Please update to the latest version 1.0.19, problems will be solved....
http://forum.firetrust.com/viewtopic.php?f=50&t=7265
Colombe
Fri Sep 03, 2010 7:36 pm
I downloaded the latest version and we will see if it's will working properly now. By the way my configuration is set on checking new versions every 2 days. I didn't get a message about this new version .19! Perhaps a suggestion for .2?
Sat Sep 04, 2010 7:57 am
They are looking at the updater it has some issues. Meanwhile if you subscribe to that topic (link at bottom of the topic) you 'll get an e-mail on each new release. Well if nothing eats your e-mail you'll get it... :cry:
