Hi
I did read another topic re this, but the suggestions therein didn't help. Just started this problem today. Worked fine this am and now wash mail is greyed out most of the time (only once in last 3-4 hours has it worked). Haven't changed any settings and FirstAlert isn't enabled. Would appreciate any help in solving/sorting this issue.
Many thanks
Wash Mail Greyed Out
Re: Wash Mail Greyed Out
Fire me some logs and I'll take a look. Go Help >> Send Support Logs >> enter chris as the Ticket Number >> enter something like Wash Mail greyed out in the description >> Send Logs.
Also reply back here once you have so I can double check it arrived OK.
Presumably too you've restarted MailWasher, if not, do that after you've sent the logs.
- Myjoe
Hi
Thanks for help; have sent logs now.
Glad to hear all well on the Mainland!
